1992 Honda Accord dies on me? Help!
Old Jul 25, 2011 | 09:20 AM
SCante001's Avatar
Default 1992 Honda Accord dies on me? Help!
I have a 92 Honda Accord EX, i have an issue with my car dieing on me while i am driving. I did check for spark and there is no spark. Any idea's what to look for would be greatly appreciated. Or anything i can test to start breaking down anything that it could be.
Old Jul 25, 2011 | 09:57 AM
SCante001's Avatar
Well i looked on the forum for any other topics that may be related to mine, i do hear the fuel pump when turning the key,my car will not start anymore. This was a intermittent issue, the last time it ran i was on the freeway and it just died on me just like it did on the streets. Could it be the distrib or more likely the relay??? thanks
Old Jul 25, 2011 | 12:13 PM
When no-start is present, check for 12V to the blk/yel wire at the distributor. If 12V is missing, the ignition switch assy is faulty (common problem). It's an easy replacement.
If 12V is present, you have a faulty ignitor or coil. Check DIY forum for links to diagnostics to check these components.
If you don't wan't to do diagnostics, there are two paths; replace coil (seems slightly more likely than ignitor) and then ignitor, hoping to hit problem first, or simply replace distributor to be certain. Cost of a rebuilt distributor is <$100, last time I checked.
Old Jul 25, 2011 | 12:26 PM
SCante001's Avatar
Default Thanks
I will call around for a used & new distrib, so that is common problem with these cars?? What do i check next if it isn't any of the things you pointed out? Just trying to get a process going to diagnos my problem. Really appreciate it!! thanks
Old Jul 25, 2011 | 07:08 PM
If you want to diagnose, download a 90-93 Accord manual from Online Manuals links in DIY forum.
Yes, distributor problems are a regular problem for most Honda's.
nfaulisi
Mar 29, 2013 06:08 PM
ryaldin
Oct 22, 2012 05:32 PM
Nicolai Hobbs
Jul 12, 2012 05:44 PM
POS-Accord92
Nov 7, 2011 06:50 PM
nickel904
Jan 4, 2011 09:54 AM
