1992 Honda Accord EX Sputtering
Old Sep 10, 2011 | 08:18 PM
Metrex1992's Avatar
Default 1992 Honda Accord EX Sputtering
I have a '92 Honda Accord EX with about 200k miles on it. When in park the car idle's fine, when I set it to reverse the car shakes badly and acts like it wants to cut off and sometimes does. When accelerating the car will sputter a few times and either take off or cut off. I've replaced the spark plugs, and the wires are only a few months old. Can't seem to figure out what is wrong with the car. Thanks in advanced!
Old Sep 10, 2011 | 08:30 PM
Any stored codes in the ecu? After that, if there are none.
Suggest, checking/replacing the cap and rotor, if they have not been done or are due.
Does this happen all the time or just when the car is cold/or only once warm?
Old Sep 10, 2011 | 08:32 PM
Metrex1992's Avatar
Happens at anytime. Earlier I just turned the car on and put it in reverse and it cut off. Sometimes it can run for a little bit then it will happen.
Old Sep 11, 2011 | 07:22 AM
Check for codes and inspect the cap and rotor. Need to rule these out before going further.
Old Sep 11, 2011 | 09:39 AM
Metrex1992's Avatar
The cap and rotor was replaced at the same time the spark plug wires were, around November 2010. I don't know how to check for any stored codes on the ECU, but wouldn't if you reset the battery it would reset the computer?
Old Sep 11, 2011 | 10:12 AM
Ok, didn't know you did the cap and rotor already, saw the plugs and wires.
At the top, there is a "Sticky"-Common DIY Threads. In there you can find out how to check for codes....IMO, finding the connector will be the hardest part of this.
Yes, you can reset them, I just hate to do that without knowing what they were. or IF there were any. Both (code or no code) can be important for the next steps.
Old Sep 11, 2011 | 10:34 AM
Your car may be running a little lean. Refer to these links:
autorepair.about.com/library/a/1h/bl458h.htm
honda-tech.com/showthread.php?t=1844067
Old Sep 11, 2011 | 10:39 AM
Here's a thread on testing the TW sensor:
https://www.hondaaccordforum.com/for...w-sensor-5682/
Old Sep 12, 2011 | 05:21 PM
Metrex1992's Avatar
How do you test the ECU? I can't find out how.
Old Jun 6, 2013 | 11:33 PM
Candice Burcham's Avatar
This is how to check the codes and what they are on the 92 honda. How to find check engine codes on a 92 Honda accord
