1992 honda accord won't turn over
Old Nov 8, 2016 | 09:14 PM
zedjr's Avatar
Default 1992 honda accord won't turn over
I have a 1992 accord ex 5 speed. The starter won't turn unless jumped. Solenoid doesn't click when starting it inside car. When key in ignition slot 1 and 2 the continuity is good and all lights light as suppose to be. When in 3 position the test failed so i replaced the ignition switch and still wont start. I have also jumped the clutch interlock switch(the two pin yellow connector near the clutch safety switch). I have also checked continuity for the ignition fuse located under the hood and it seems fine. Have also checked all the fuses by the foot kick box. Am now at a total loss and need help. My car was stolen and after it was stolen it would start randomly for a while and now doesn't start at all. So I am assuming it has something to do with that. Maybe a burnt wire i thought but all key positions provide power to everything else it just won't send power to starter?Any help is appreciated.
Old Nov 9, 2016 | 07:21 AM
Suggest confirming 12V start signal is not arriving at starter on B/W wire. If missing work backwards from starter to see where signal is lost,... or forward from ignition switch on column. A wiring diagram is necessary to guide diagnosis.
Old Nov 9, 2016 | 11:23 PM
zedjr's Avatar
i am currently doing that, ruled out everything except it be the starter cut relay or a bad ground. I finally found what i believe to be the starter cut relay. It was loose and not attached. Is it suppose to click as mine does not click. I will try to jump it tomorrow and investigate any bad grounds to starter cut relay. Is there a clutch cutoff relay also? Also does anyone know of the grounds for teh ignition to starter wire that i can check? It has to be one of these two or just a burnt wire. Any help is appreciated.
Jenny Jordan
Dec 22, 2023 11:04 AM
mattmosman
Jul 30, 2012 06:48 PM
waterskier2
May 10, 2011 01:40 AM
Blinkinlights
Jul 3, 2010 10:10 PM
02ATownChevy
May 15, 2009 05:50 PM
