94 Accord..Won't Turn Over
Old May 15, 2009 | 08:41 AM
02ATownChevy
Default 94 Accord..Won't Turn Over
I am having a problem with a 94 Accord...Its for a friend and i am stuck at this point, trying to find out what is the next step to take...Installed a brand new battery car seemed to be fine, drove it a couple times and then it just went dead..Pulled the altenator off had it checked out and rebuilt...installed the altenator back, put the battery cables back on and i am getting nothing, no power to anything, dome light, headlights, dash lights, nothing...car won';t even attempt to turn over...so took my battery out my truck just to check and still nothing...where do i go next? Any help would be appreciated, its for an older woman i know and i am only doing this as a favor...please help
Old May 15, 2009 | 09:15 AM
hondadude's Avatar
The first thing I'd do is to check the main fuses in the underhood fuse box.
Old May 15, 2009 | 10:13 AM
Corroded or loose battery cables? Not at the battery but at the opposite ends.
Old May 15, 2009 | 11:05 AM
Unhappy
Possible starter motor pinion jammed in flywheel ring gear..also make sure your transmission is solidly engaged in PARK .
Old May 15, 2009 | 05:50 PM
deserthonda's Avatar
first thing that i would chk is to make sure that the cables are tight and not corroded. battery is still fully charged . if those are ok i would start checking the main fuses
mattmosman
Jul 30, 2012 06:48 PM
ClaytoniousMonk
Jul 22, 2011 04:09 PM
waterskier2
May 10, 2011 01:40 AM
waterskier2
Apr 19, 2011 03:37 PM
Blinkinlights
Jul 3, 2010 10:10 PM
