1993 Accord Driver's Power Window
Hi,
I have a 1993 honda accord station wagon and recently the driver's window intermittently stopped going up. I suspected that it was the switch, so I cleaned the assembly and got most of the black gunk out of it. This failed to help the problem, so I took the window motor assembly out and that relieved the stress of the window, however it only worked intermittently. From there I tested the voltage coming from the connector to the window (red-blue and red-yellow). When the window switch is pushed down it is -11.24 volts, however when pushed up it it can be within the range of 1-2 volts.
I am out of ideas of what is going wrong, unless the drivers power window control box is broken. Please advise what I should do next. Thanks!
A high resistance is sapping the voltage transmitted to the motor. Switch seems likely culprit despite cleaning. Did you disasemble switches and clean contacts?
Suggest trying to swap a switch from another position to driver's position to see if that fixes problem.
jza240sx
Apr 30, 2013 04:14 PM
