1993 Accord EX A/C not working
Old Sep 16, 2010 | 10:04 PM
CrazyCarGuy's Avatar
Default 1993 Accord EX A/C not working
The compressor will kick on. We replaced the switch on the dash panel. The fuse is good. So we are thinking it is the blower relay (above the interior fuse panel, correct?) or the actual blower behind the glove box? Any suggestions? Also which relay is the A/C blower relay above the fuse panel? Looks like there are 5 relays?
Attached Thumbnails 1993 Accord EX A/C not working-accordrelays.jpg
Old Sep 16, 2010 | 10:41 PM
I am guessing that the motor inside of the car is not working to push air through the vents?
A caveman test is to turn on the blower motor, hit the area around the motor and see if it turns on. If it does, likely a bad motor or loose connection.
You can also unplug the two pin connector to the blower motor, turn on the blower motor. Use a volt meter to see if you have 12V across the pins.
Old Sep 16, 2010 | 10:45 PM
Thanks for the idea, we will try that in the morning!
patpend
Sep 15, 2011 05:46 AM
neffster
May 21, 2011 08:15 AM
MoDawG
Dec 10, 2009 07:00 AM
sthavorn
Apr 7, 2007 10:12 PM
arunsam3000
Mar 6, 2007 01:40 PM
