1993 accord ex tires
Old Dec 30, 2009 | 04:44 PM
kirakitty's Avatar
Default 1993 accord ex tires
The lovely New York pot holes have given me the gift if a big ugly bubble on the passenger side. I know your all jealous. Are there other tire sizes that will fit comfortably on the car, my car calls out 195-60/15, I was told 195-65/15 are OK.
Is there a chart around? I checked Tire Rack and they only give the option to increase the wheel diameter to 16, 17 or 18", not an alternate tire size for the 15" rim.
Thanks
Old Dec 30, 2009 | 10:46 PM
91excoupe's Avatar
195/65 15's will be a bit taller than stock... a 205/60 or a 215/55 should be pretty similar in overall size to stock...
here's a link to a handy calculator that converts tire size to overall diameter,...
if you stay within a half inch or so of stock (24.213in) your speedometer should stay accurate to within +/- 3mph... hope this helps
Old Dec 31, 2009 | 01:06 AM
Arrow Take A Look At
In the Tire and Wheel Forum at the top we have put in Non Selling links to tire and wheel calculators for all members usage...
Old Jan 1, 2010 | 01:43 PM
finch13's Avatar
Thanks
Put the correct size on, this will keep the car handling/steering/acceleration/braking the same. The correct size is on the door jamb sticker.
Telling us a year and model is also helpful. Although this is an Accord forum, you can't assume every single Accord is the same.
Increasing the aspect ratio is not an increase in diameter. It's still a 15" tire that is 195mm wide, what you're changing it the height of the sidewall from 65% of 195 to 60% of 195.
NorthCountry
Mar 30, 2015 08:37 PM
fawaan
Jun 27, 2011 04:04 PM
starbai
Aug 27, 2008 08:26 PM
maro
Mar 10, 2007 12:15 AM
Mpwr
Jun 20, 2006 02:23 AM
