1993 accord loose power
Old Apr 29, 2013 | 08:27 PM
phatdad's Avatar
Default 1993 accord loose power
say I'm driving at 45 mph all of a suden the car will loose power I can push on gas pedal but it as nothing happens the car will do about 20 mph no mater how hard I press the pedal car has 250,000 on it but otherwise runs great
it seems to do it more if it is raining . I have sprayed all connectors under hood with a spray bottle of water including the cap and rotor and plug wires
Old Apr 29, 2013 | 09:36 PM
UhOh's Avatar
not giving us a lot of info, but I'd look at distributor function
if it's been getting worse in the last 1000 miles.
O-ring oil leak to dist. caused my '93 to stop at edge of road
when I ignored intermittent total loss of power.
New dist. fixed it. Some $.
Old Apr 30, 2013 | 06:30 PM
Is/does/has the CEL come on at any point while the engine is running?
When was the last tune up?
Old May 1, 2013 | 05:20 AM
phatdad's Avatar
no Cel cap rotor plugs and wires within the last 4 the month
Old May 1, 2013 | 08:01 AM
kayweb's Avatar
fuel pump, filter? My exgirlfriend's focus had a pump start to die on a highway in montana and it wouldn't go faster than about 25
edit: 93s didn't come carbureted, right?
Old May 2, 2013 | 05:56 PM
When you replaced the cap, was there a new o-ring with it? Wild guess on that one.
Check the connector on the O2, these can become lazy and cause issues without setting a code.
trueno86
Apr 8, 2013 01:54 PM
bhollehday
Feb 7, 2013 10:44 AM
chucktaylorfan92
Jun 21, 2012 03:20 PM
spezticle
Mar 20, 2009 03:26 AM
billeethakid
Jun 11, 2007 07:33 PM
