My daughter has a 1993 Accord. When you start the car the RPM goes from 1000-5000 and then back. It continues to go up and down. Does anyone know what his could be? My daughter had to have the car towed to the house. The linkage isn't stuck.
Be sure the engine is full of coolant and block burped thru the 12mm bleed port at the
t-stat housing.
Next would be to check the FITV, you can take the lid off [ 2 phillips screws] and look in to see the brass cone sticking up in the center of the screw ring.
When cold the cone is down/open to allow extra air thru, when warm you should not be able to hear air bypassing.
You can turn the screw ring down a few turns until the idle surge goes away.
t-stat housing.
no there isn't a light on. There is a little light that says maintenance required
Tags
1993, 93, accord, acord, check, engine, gauge, gauges, gos, honda, light, proper, rpm, rpms, wrong
- 1993 Honda Accord automatic idle jumps to 1200 rpm when put in gear
- 3000 rpm idle 1993 Honda Accord, I can't think of what to check next
- Will 1993 Honda Accord engine fit in a 1987 Accord?
- 1993 Honda Accord SE, if the engine is idling above 1 RPM the engine thumps!
- 1993 Accord LX 170K - rising idle rpm in stop and go traffic
