1993 Accord- RPM
Old Oct 9, 2009 | 02:43 PM
1994accord
Default 1993 Accord- RPM
My daughter has a 1993 Accord. When you start the car the RPM goes from 1000-5000 and then back. It continues to go up and down. Does anyone know what his could be? My daughter had to have the car towed to the house. The linkage isn't stuck.
Old Oct 9, 2009 | 03:23 PM
Is the check engine light on?
Old Oct 9, 2009 | 03:37 PM
hondadude's Avatar
Be sure the engine is full of coolant and block burped thru the 12mm bleed port at the
t-stat housing.
Next would be to check the FITV, you can take the lid off [ 2 phillips screws] and look in to see the brass cone sticking up in the center of the screw ring.
When cold the cone is down/open to allow extra air thru, when warm you should not be able to hear air bypassing.
You can turn the screw ring down a few turns until the idle surge goes away.
Old Oct 9, 2009 | 03:38 PM
1994accord
no there isn't a light on. There is a little light that says maintenance required
Old Oct 9, 2009 | 04:19 PM
I just want to be thorough. Do the actual engine RPMs go up and down, or is it just the gauge?
Old Oct 9, 2009 | 04:46 PM
Jahg77
Check this. Remove and clean, the screen is might be black and cloudy or buy another.
Old Oct 9, 2009 | 04:48 PM
Jahg77
Removed and clean with brake fluid. this part or buy another..[
bassinflats
Jun 9, 2013 08:55 AM
roadki1
Oct 17, 2010 12:26 PM
45below
Sep 16, 2010 03:26 PM
SE_Accord 93
Aug 17, 2009 05:19 AM
aatc20
Aug 24, 2006 01:20 PM
