1993 civic dx idle problem
Old Apr 10, 2014 | 02:14 PM
volvoman's Avatar
Default 1993 civic dx idle problem
started idling real rough,will cut off when stoped,changed plugs rotor,cap.no change.i unplugged IAC and car shut off.is IAC the problem?
Old Apr 10, 2014 | 04:08 PM
Not completely familiar with Civic idle-control system...
A friend had a 2000 Civic and the idle control system wasn't the same as Accords. Procedure for setting it up was NOT the same as my post in DIY about setting the BASE idle.
Still, when you unplug the IACV it should drop low. So if it's already too low, then unplugging the IACV will make it stall.
You need a manual for the procedure for properly setting the idle.
Old Apr 10, 2014 | 05:08 PM
volvoman's Avatar
Default 93 civic
Jim im so sorry.i own 92 accord and 93 civic.i am so use to posting on this forum( which is great by the way),i forgot i was asking civic question.
Old Apr 10, 2014 | 06:26 PM
Hey, we try to help all. You have an Accord and are a member here, if we can help with other things we will. Heck I've posted about a Saab and a Volvo on here just trying to get ideas and advise.
Like Jim, not real good with the civic but think about the basic's. I'd bet they have an IACV of some sorts. So look for that and as always a good clening of the TB while there never hurts.
Old Apr 11, 2014 | 09:19 AM
My friends 2000 Civic had an IACV, but the download shop-manual had a procedure for setting the idle that was completely different from the Accord procedure. I was simply warning that you shouldn't just use the Accord procedure.
I bet you could find a 93 Civic shop manual at the same place as the download manuals that are linked from the "common-DIY" thread.
There IS a "sister-forum" www.hondacivicforum.com where I'm not a moderator. Frankly I haven't spent enough time on that forum to be able to tell you where to find a good thread on the subject.
lovely4
Oct 21, 2014 07:44 PM
Doc_G
Dec 14, 2010 06:39 PM
mstakern
May 26, 2009 08:59 PM
bristow
Jul 24, 2007 06:48 PM
aatc20
Aug 24, 2006 01:20 PM
