1993 Honda Accord LX- left tail light lens removal
Old Oct 14, 2015 | 12:28 PM
tomp's Avatar
Default 1993 Honda Accord LX- left tail light lens removal
New to the Honda world, so please be kind with your comments.
I just purchased a 93 accord lx sedan, and i noticed the LEFT side tail light has a build up of water, and also some kind of leafy things at the bottom(the WHITE part of the tail light lens.
I removed the assembly, took a hose to the inside, but the green, leafy stuff is not reachable through the hole. It seems like its on the other side.
My question is, i would like to pull the lens away from the assembly , but i am having a hard time figuring out the best way to do it, without breaking the lens.
I am sure there is some type of sealant holding the plastic assembly to the lens, but i am not sure if i am missing something else, that needs to be removed, or unbolted.
Any tips or guidance would be greatly appreciated. Thank you!!!
Old Oct 14, 2015 | 03:22 PM
I always thought the parts were plastically welded together. I had a leak in a 90 Accord that new foam gaskets would not fix. I drilled a drain hole to allow water to drain. This was a fix.
Leaf may be algae that has grown in the water.
Check ebay and amazon for replacement and used parts.
Old Oct 14, 2015 | 03:52 PM
tomp's Avatar
Thank you for the reply.
I had no luck at the junkyard today finding a replacement .
Maybe i will try the "drill " method, since i got pretty much all the water out of the lens, but not the "algae".
Old Oct 17, 2015 | 05:54 AM
You might try some cleaner (simple green, purple cleaner, ect) and see if that will get some of the growth out of there.
As TX said, ebay or car-part might be a place to look for a replacement.
Duck95
Apr 10, 2014 03:08 PM
TexasHonda
Oct 30, 2011 03:57 PM
t.s.carter87
May 10, 2011 08:11 PM
Dono2004
Mar 13, 2010 08:55 PM
clothesline
Jan 23, 2010 03:06 PM
