1993 Honda Accord LX- left tail light lens removal
New to the Honda world, so please be kind with your comments.
I just purchased a 93 accord lx sedan, and i noticed the LEFT side tail light has a build up of water, and also some kind of leafy things at the bottom(the WHITE part of the tail light lens.
I removed the assembly, took a hose to the inside, but the green, leafy stuff is not reachable through the hole. It seems like its on the other side.
My question is, i would like to pull the lens away from the assembly , but i am having a hard time figuring out the best way to do it, without breaking the lens.
I am sure there is some type of sealant holding the plastic assembly to the lens, but i am not sure if i am missing something else, that needs to be removed, or unbolted.
Any tips or guidance would be greatly appreciated. Thank you!!!
I always thought the parts were plastically welded together. I had a leak in a 90 Accord that new foam gaskets would not fix. I drilled a drain hole to allow water to drain. This was a fix.
Leaf may be algae that has grown in the water.
Check ebay and amazon for replacement and used parts.
t.s.carter87
May 10, 2011 08:11 PM
