1993 Honda Accord Wagon
Old Nov 19, 2011 | 03:40 PM
nando1032's Avatar
Default 1993 Honda Accord Wagon
My Wagon died on me a couple of months, I thought it was the ignition coil, so i went ahead and bought an ignition coil, but come to find out that is still doing the same not starting, I removed the Cap from the distributor and i notice that the rotor does not moved or the gears inside the distributor, I ck the front pullies and they do move also the flywheel thought the timing light opening, does any one have any idea what might be the issue and what can done to resolve it.
Thank you for any assistance!
nando
Old Nov 19, 2011 | 06:37 PM
Remove oil fill cap and see if you can observe valve train movement when engine is turned. This would confirm camshaft is rotating.
If camshaft is not rotating, the timing belt has broken. This would mean likely valve damage when valves hit pistons. Cylinder head will need to be removed, rebuilt, and reinstalled.
How many miles? Has timing belt ever been replaced?
xander15
Mar 1, 2015 03:18 PM
daver1100
May 8, 2014 02:41 PM
mullet93
May 20, 2013 08:46 PM
3ringcircus
Feb 19, 2012 08:23 PM
catniprocks
Apr 7, 2008 09:28 AM
