1993 Manual Transmission Issue Tonight
Old Apr 30, 2008 | 09:04 PM
RoKnAzn's Avatar
Default 1993 Manual Transmission Issue Tonight
Well, I was at a stop light after eating at a Mexican Restrauant tonight. This car was not paying attendent and almost rear ended me. I save my car by Popping the clutch and hauled *** forward. Now the problem is that its stuck in second gear....IDK what happen? I press the clutch in and out and it works fine but its stuck in gear....What is going on?
Thanks
Anthony
Old Apr 30, 2008 | 10:39 PM
Default RE: 1993 Manual Transmission Issue Tonight
Does the shift **** move at all?
Have someone push the clutch in and look at the slave cylinder. See if the slave cylinder is pushing the shift fork.
Old Apr 30, 2008 | 11:02 PM
RoKnAzn's Avatar
Yes, the shifter moves....I can shift in to first but it fights where the other gear (stuck in Second). IDK what is going on....Any input?
Old May 4, 2008 | 03:24 AM
RoKnAzn's Avatar
Well, I had a Very Violant Vibrations when I was rev in first gear and shifting in to second. Also, I can leave the shifter in Neutral and when I release the clutch it start going (its stuck in second).....
Old May 6, 2008 | 01:09 AM
RoKnAzn's Avatar
Hello......Anyone?
Old May 6, 2008 | 07:13 AM
When the shifter is in neutral, the tranny is in 2nd? Maybe the 1-2 shift fork is broken? But then it wouldn't do anything when you shift to 1st. Whathappens when you shift to 3rd or 4th?
Old May 6, 2008 | 11:06 PM
RoKnAzn's Avatar
ORIGINAL: JimBlake
Yes, when the shifter is in neutral. The Tranny is in 2nd. When I put the shifter in 1st. The tranny fights with first and stall the motor out. Same with 3-5 and Reverse...
Old May 7, 2008 | 10:00 AM
I understand 3, 4, 5, & R, but I don't understand 1st. 1st & 2nd gears sharea synchro hub betweenthem. If it's stuck in the position locking 2nd to the shaft, I don't see how you can even move it to 1st.
A broken shift fork would allow you to move the shift lever to 1st but it wouldn't actually move the synchro hub. So that seems to eliminate a broken 1-2 shift fork.
Now I'm thinking the 2nd-gear baulk ring is seized onto the 2nd gear cone. I guess that would lock 2nd gear to the shaft, while allowing the hub to slide to neutral & over to the 1st-gear position.
Been running the tranny with not enough oil?
Old May 7, 2008 | 01:20 PM
RoKnAzn's Avatar
Well, I put the shifter in to second and rev the motor to almost redline. I got a very viloent vibration and i was about to shift to 3rd...WTH is going on...Now I am able to drive it normally...
Old May 7, 2008 | 01:28 PM
So now it works OK??
I guess that DOES fit with the baulk ring seized to the gear cone. You managed to break it free & now it works.
I imagine shifting INTO 2nd (from either direction) might be a little rough for awhile.
Check your tranny oil level.
