1993 No fuel after engine swap!!!
Old Dec 6, 2008 | 08:02 PM
Default RE: 1993 No fuel after engine swap!!!
ORIGINAL: hondadude
Ground wire at T-stat housing
Yes.
Hey, markwolfe07,I never meant that you should ignore all the other suggestions. Did you check that ground wire? OTOH, that ground wire would cause a problem across the board, not just 2 & 3. Sounds like the resistor box is a good place to look.
Old Dec 7, 2008 | 06:49 AM
markwolfe07's Avatar
Sorry, but I did check the ground. I don't ignore any suggestions because this aint my strong suit! Now, got to start checking some more. I hope its just a loose connection. LMAO!!!
Old Dec 7, 2008 | 07:05 AM
I forgot to ask. Where is the resistor box?
Old Dec 7, 2008 | 06:32 PM
Well problem solved! Thanks to all for your help. FYI there are two 6 pin connectors, one male and one femalein the engine wiring harness, drivers side. One 6 pin male on top of the fender well and a 6 pin female on the injector resistor box. If you connect harness to harness and fender well to injector box, no power to #2 & #3 injectors! I got some nice tags and markers from work for the son and his buddy to label the connections. SOMEONE did not think it was necessary because all the plugs were different. Sooooo who wins this weeks dumb a** award? Probably Dad right???
Old Dec 7, 2008 | 07:11 PM
Glad that you got it figured out and it was something simple to fix. It was just a pain to isolate the problem.
robertrodriguez1165@yahoo.com
Aug 1, 2012 02:26 PM
Jul 23, 2012 04:56 PM
Jul 23, 2012 03:07 PM
markwolfe07
Nov 12, 2008 07:56 AM
