1994 accord ex ??
Old Sep 30, 2012 | 07:07 PM
jboggs04's Avatar
Question 1994 accord ex ??
I have a 1994 accord ex 4 cylinder manual transmission. The instrument clusters lights for the speedometer, tac gauge are not working i've replaced the 4 lights in the cluster and still doesn't work. All fuses under the dash and under the hood are new and work fine. What else could it be??? Where should i go from here????
Old Sep 30, 2012 | 11:34 PM
Hi New Member..I shall move you to the correct posting forum for your question..
Old Oct 1, 2012 | 10:09 AM
jboggs04's Avatar
Thank you,
Old Oct 1, 2012 | 07:53 PM
Pull the dimmer switch, headlights on. Ground the RED wire, do the dash lights go "full bright"? If you have a volt meter, check the voltage on the RED/BLK for voltage to ground.
faran
Aug 1, 2016 06:07 PM
dswiz1984
Oct 17, 2008 09:10 PM
shinobi16
Aug 7, 2005 09:43 PM
Apr 10, 2005 12:22 PM
Jan 6, 2005 11:35 PM
