1994 honda accord ex motor swap into a 1996 accord lx
Old Oct 17, 2008 | 06:50 PM
dswiz1984
Default 1994 honda accord ex motor swap into a 1996 accord lx
Im having problems with my 1996 honda accord lx. i just swaped a motor out of a 1994 accord ex wich the motor was a v-tec, everything went smoothly. everything pluged in ok, except for the computer. the plugs were different on the 94 ecu so i left the 96 ecu in the car. the fuel pump cuts on &the motor is getting fire. but the car just wont start. what do i do?
Old Oct 17, 2008 | 09:10 PM
Default RE: 1994 honda accord ex motor swap into a 1996 accord lx
well thats the problem with trying to run a obd1 motor with a obd2 ecu, although thearetically it still should run, you should just get a list of CELs a mile long. If your state does not have state inspections i would recommend buying a obd2-1 conversion harness so you can use the 94 ecu, they are about $75. however if your state does have state inspection you will fail it if you do this
Woodall
Mar 4, 2014 04:21 AM
cd51994accord
Jan 30, 2014 12:56 PM
cd5dj302
Jul 7, 2013 08:39 AM
grim_reaper
Apr 2, 2012 10:32 PM
xkuma
Jun 23, 2007 08:57 PM
