1994 Accord Trouble Starting
Old May 24, 2006 | 07:49 PM
joeeeee
Default 1994 Accord Trouble Starting
I have a 1994 Accord and it wont start when it sits in sun and gets hot. Just had fuel pump replace for 300 bucks and now i have the same problem. it sits in 85 degrees in sun and it just turns over and over and wont fire. Please help or next time it starts i might drive it off a bridge.
JOE
Old May 24, 2006 | 08:44 PM
Chiovnidca's Avatar
Default RE: 1994 Accord Trouble Starting
Have you checked the main relay for cracked solder joints?
Old May 24, 2006 | 08:51 PM
joeeeee
No I have not I will do it tonight thanks alot i'll let you know if it works.
Old May 24, 2006 | 09:02 PM
sir_nasty's Avatar
have you done any testing on it when it doesn't start to see if it's getting fuel and spark?
Old May 24, 2006 | 09:12 PM
joeeeee
No not when problem occurs it always happens when im at work but i will i did check fuel line before fuel pump was replaced and it was barely dripping out so I replaced fuel pump but something is still wrong so i'll try that too. Thanks I appreciate all and everyones comments.
Old May 25, 2006 | 03:39 AM
deserthonda's Avatar
ahy ahy ahy........Joeeeeee..........I just wish for your sake that you would have come here before replacing the fuel pump.........
A very common problem on these cars after car has been sitting in hot weather ( humid ) and will not start , is the MAIN relay loose soldering ..
remove the relay and chk it out ,, if any cracked solderings, resolder them or replace relay,,
if you go to the DIY section of this forum, there is a write up on HOW TO fix main relay....
Old May 25, 2006 | 05:33 PM
joeeeee
Thanks for advice ill let everyone know how it turns out
Old Jun 27, 2007 | 09:57 PM
zero9243's Avatar
sorry to bring back an old thread, the link is no longer working, any tips?
Old Jun 27, 2007 | 10:30 PM
try this...
http://techauto.te.funpic.org/
stevwil41
Nov 3, 2011 09:36 AM
JOEKIR
Aug 17, 2011 09:20 AM
engtaz
Jun 10, 2011 06:52 AM
dametalone
Jul 13, 2010 07:44 PM
Stevie3D
May 23, 2008 06:38 PM
