1994 Honda Accord Electrical Problems
Old Feb 5, 2011 | 10:40 AM
HondaNatey's Avatar
Default 1994 Honda Accord Electrical Problems
I have a 94 honda accord ex. The interior light always blows it fuse and now the condenser fan (which gives me heat, air and defroster) fuse blows too. I am thinking there is a short somewhere but I am not sure of how to test or locate the problem. Any leads or help is appreciated.
Old Feb 5, 2011 | 11:09 AM
I'm thinking the two are not related. Heat right now is important so let's start there. I'd test the blower motor first, see if the motor has shorted out inside.
Old Feb 5, 2011 | 11:31 AM
Condensor fan is the driver's side cooling fan for radiator. It is likely a defective motor. Unplug the motor connector and see if fuse does not blow. Motor connector is not easy to access! You may have to pull the under body dust shield to access from beneath.
If condensor motor is bad, you can drive (no AC use) until you can buy a replacement and install. Check ebay for a replacement motor to install on your fan/frame. Fairly inexpensive, probalby $30-$50.
Old Feb 5, 2011 | 01:37 PM
Originally Posted by HondaNatey
now the condenser fan (which gives me heat, air and defroster) fuse blows too. .
I was going with the blower motor (inside the car that pushes air out the vents) based on the above.....
Old Mar 10, 2011 | 04:13 PM
findleyjh's Avatar
Default '94 Honda Accord LX with same problem
Hey,
Just wondering if there's any resolution to this problem because I have a similar situation. Perhaps it's just coincidence. But my Honda continuously blows the fuse for the interior light also, while at the same time, I just started having issues with the blower motor.
Any others experience the same seemingly unrelated symptoms?
Cheers,
Jim
Old Mar 10, 2011 | 08:02 PM
What issues are you having with the blower? Does it not work at all or something else. Does it sometimes work then just stop, does the fuse blow when it stops.
Old Mar 11, 2011 | 10:01 AM
findleyjh's Avatar
So it's not the blower per se with which I am concerned. I suspect either the resistor or the motor itself is going, and I can swap them out (once it's warmer outside). Also the blower motor circuit fuse does not blow.
But the fuse on the light circuit blows soon after replacement; and, it seems to me it may have started sometime soon before the problem with the blower started. So I'm wondering if the two MIGHT somehow be connected in a way I don't understand.
If I put a new fuse in the light circuit and DO NOT USE the blower, would that tell me if the two are related?
Hope that help explain my quandry and line of thought...cheers.
Old Mar 11, 2011 | 12:06 PM
Try unplugging the wire harness from the blower motor. Does the fuse blow if you turn on the blower switch?
Then try unplugging the speed-control resistor & try again. Then the blower speed-control dial...
Yankee30
Apr 24, 2013 06:54 AM
phr3shaccord
Oct 18, 2011 12:00 PM
HondaBobo
Jun 14, 2011 07:07 PM
chillnndc
Nov 27, 2010 09:05 AM
eze123
Jul 16, 2010 12:29 AM
