1994 Honda Accord Slams into Drive or Reverse
Old Aug 13, 2012 | 01:53 PM
gabrielbyrnei's Avatar
Default 1994 Honda Accord Slams into Drive or Reverse
Hello everyone, i've got a little problem going on my Accord.
Whenever i switch between Drive and Reverse, the car slams, like a strong push forward.
The car only has 80k miles on it, had it from brand new. Has been to every single one of the dealership maintenance schedules.
Although, reading through some of the work done on the car, i read the dealership used "ATF Plus 4" and not the Honda specific ATF.
Recently i made a transmission oil change with authentic Honda ATF, some 500 miles ago, along with cleaning the 2 solenoid valves (Shift solenoid and lock up solenoid). The slam went away, but returned after 50 or so miles.
The car shifts a bit rough between 1st and 2nd gear, but from 2nd to 3rd to 4th, its barely noticeable.
What could it be, im really lost. Thanks!
Old Aug 13, 2012 | 02:27 PM
Check the mounts, front and rear.
Old Aug 13, 2012 | 07:33 PM
Forgot to mention, the slamming only happens when the engine is cold
Old Aug 13, 2012 | 08:10 PM
Silver6gen's Avatar
Not good news for the transmission.... I'd put money that the bearing guides failing
Old Aug 14, 2012 | 06:17 PM
Check the mounts as a start....Thanks
Old Aug 14, 2012 | 06:25 PM
All mounts are in good shape, engine and transmission.
The only two posible explanations that come to my mind are, either its the ATF 4+ thats causing the problems (already did a drain and refill once with aunthentic Honda ATF) or the transmission is really dying.
Any ideas?
Old Aug 14, 2012 | 06:50 PM
Adjustment of the transmission throttle cable can greatly affect shift quality.
Old Aug 14, 2012 | 06:54 PM
Would that TV Cable affect the slamming when D<->R ?
Old Aug 14, 2012 | 07:01 PM
No, I don't think trans throttle will affect idle shift response. It will affect 1-2 shift however.
Have you carefully checked rear motor mount?
Old Aug 14, 2012 | 07:03 PM
Yes, my mechanic checked them on 2 different occasions, and said they were ok.
