1994 Honda Accord sputtering low idle
Old Jun 4, 2020 | 01:05 AM
blackhatchic1's Avatar
Default 1994 Honda Accord sputtering low idle
All of a sudden did a noticeable mis and a few days later started sputtering and will barely idle but it's doesn't sputter at 60 mph. Also D4 is flashing, added transmission fluid. check engine light comes on but doesn't stay on. I have an obd 2 but it's an obd1.I changed plugs & they needed to be changed but it didn't help the issue. Ive never had any problems out of this car. I really need help as Im a widow and have to try and fix it in my own. Any help will be deeply appreciated
Old Jun 4, 2020 | 08:06 AM
Follow the instructions on this thread to read the OBD1 codes. Post the codes you read and specify the light (D4 or CEL) that gave the code.
https://www.hondaaccordforum.com/for...l-codes-35962/
Old Jun 5, 2020 | 10:41 PM
ok & what would you suggest i use? a paper clip or just a piece of wire? & is it going to shock me?
Old Jun 6, 2020 | 01:01 PM
The Toecutter's Avatar
Paper clip if you have one, if not a piece of bare wire will work. No it won't shock you. Other than how easy it is to do.
tmealer
Mar 11, 2013 10:46 PM
mtwallet
Jan 20, 2013 02:34 PM
Jason Allen Hines
Sep 24, 2012 09:44 PM
d_10
Jul 15, 2007 12:33 PM
FlyLow
May 12, 2006 10:15 PM
