1994 honda civic ex swap from d16z6 to f22a
Old Jul 13, 2020 | 03:46 PM
Richard.e's Avatar
Default 1994 honda civic ex swap from d16z6 to f22a
i need help with some questions i have about this swap
1.) will h22 swap mounts work with the f22
2.) i have the harness and everything to hookup but can i use my original ecu or do i have to get a honda accord ecu
3.) my brother pulled the d16z6 and lost all the bolts to everything where can i find bolts for the engine and evrything else he lost?
any answers are appreciated as i want to get my car up and running as soon as possible
Old Jul 13, 2020 | 09:35 PM
I'm a bit confused as I am not familiar with Civic engine numbers. Are you trying to install a F22 engine from an accord into a 94 Civic EX engine bay? What year accord is the source of the engine? Is d16z6 the original engine for your Civic?
1. Are the H22 swap mounts designed for your Civic engine bay?
2. The ECU necessary will depend on the engine you are using and what transmission are you using? I'm guessing a manual transmission?
3. You can always buy new bolts online from Honda, but it will be expensive. A u-pull-it junkyard has always been a good source for OEM bolts for me. I'm not sure what bolts you are missing specifically.
Old Jul 15, 2020 | 09:11 AM
The Toecutter's Avatar
I think H style engine mounts are very similar to f mounts. I only say that as I knew a guy who pulled his f engine out and replaced it with an H engine, and other than the harness everything went back in. The changes in the harness were because of the ECU. Depending on which ECU you have, you might be able to use it.
Old Jul 15, 2020 | 02:59 PM
The question about the ECU isn't clear to me. Use your original D16 ECU on the F22? I doubt that would work properly.
And it isn't a "Civic ECU" vs an "Accord ECU" anyway. There can be differences between versions and model-years for both types of cars. You want the ECU to match the engine.
Hswapaccord1989
Apr 11, 2016 12:30 PM
cgaccord
Apr 22, 2013 07:39 PM
Slammedcd7
Apr 3, 2012 10:16 PM
abit2theright
Feb 14, 2008 09:57 PM
charly
Oct 5, 2006 09:29 AM
