1994 Honda manual transmission
Old Sep 10, 2017 | 07:12 PM
Natasha Cherti's Avatar
Default 1994 Honda manual transmission
Just got this car less than a month ago. While driving the transmission stopped working. Shifter in to gear but not actually being engaging to move. Will start when pushing clutch in and gear shifter moving into all gears. But when releasing clutch nothing happens except for engine revving. What's wrong? And how can I fix this?
Old Sep 11, 2017 | 07:31 AM
Any work done recently? Like axle replacement?
Does the shift lever feel normal shifting into all the gears? Or is the lever just free to move every which way? That might be shift cables broken or disconnected.
When you think you've shifted into gear, and let up the clutch pedal, does the speedometer register anything? If it does, then maybe one axle has popped out just enough to spin.
Last thing is a worn-out clutch. Has it been slipping? They don't normally go completely & suddenly without slipping for awhile.
cliff
Apr 15, 2013 02:27 PM
andrestoltz
Aug 13, 2012 10:20 AM
devilzx
Jun 11, 2012 08:16 PM
Max Utility
May 19, 2011 12:32 AM
saanich
Sep 29, 2009 02:41 AM
