1994 starter stays engaged ?
Old Apr 22, 2014 | 01:12 PM
wnbasac's Avatar
Default 1994 starter stays engaged ?
starter stays engaged will running and when turned off?
will this relay fix the problem Part Number: 39762-SG0-003?
is there a difference form models, dx,lx,ex?
not sure where its located on the car as i found this on the world wide internet
tks, for your help
Old Apr 22, 2014 | 02:48 PM
Only manual trans have a start signal relay. Autos only have signal from ignition switch to starter solenoid (a relay).
This problem can be caused by dragging starter movement. On some cars it causes overspeed of starter. If this is occuring the starter is being driven at high speed and may be damaged.
Old Apr 22, 2014 | 04:55 PM
wnbasac's Avatar
tks, for your reply i guess ill just take it into the shop and let them pull the starter out
Old Apr 22, 2014 | 05:36 PM
Talking http://www.hondaaccordforum.com/forum/images/smilies/biggrin.gif
You can also take out your starter and take it to your local AutoZone/Advance/O'ewilys and have them bench trsted to see if the starters are good.
Old Apr 22, 2014 | 05:55 PM
wnbasac's Avatar
would they be able to check to see if somethings wrong with it?
it starts fine but the starter stays engaged while running and after its turned off?
Old Apr 22, 2014 | 06:18 PM
I'm with Ang - pulling the starter is not that bad. From there, two choices.
1. Give the bedix a good cleaning and then re-lube, re-install the starter and see what you have? Or you can "bench" test it yourself before installing it.
2. Take it to almost any parts store and have them test it.
But you did make a statement about it staying running with the key off? Can you give more details about this statement.
Old Apr 22, 2014 | 06:59 PM
wnbasac's Avatar
It just started as when you start the car you can hear the starter is still engaged and when you turn the car off the starter is turning the motor over for about 2-3 min before stopping
Old Apr 22, 2014 | 07:16 PM
holmesnmanny's Avatar
Sounds like it's sticking, how is the key lock cylinder, is it refusing to spring back ? Can you take the key out without turning back to the 0 position ? If yes, replace the lock cylinder first.
Old Apr 22, 2014 | 07:29 PM
wnbasac's Avatar
No the key doesn't come out but the car was stolen before with a shaved key?
Old Apr 23, 2014 | 04:01 PM
i would swap out the lock cylinder ...its not hard to do
