1995 2.2 Liter 4 cylinder VTEC valve lash adjustment
Hi, have a 95 Accord 2.2 4cylinder VTEC and new timing belt job will be done soon while the valve cover is off would like to check if "valve lash are within spec" but can not find the specs for intake or exhaust. Do any of you know a reliable source to find the specs? Thank you.
Should be a sticker under your hood with the valve clearance. Here are the SAE and metric values from the shop manual.
Intake: 0.010 +/- 0.0008 inches (0.009 to 0.011 inches) 0.26 +/- 0.02 mm Exhaust: 0.012 +/- 0.0008 inches (0.011 to 0.13 inches) 0.30 +/- 0.02 mm |
Thank you
Originally Posted by PAhonda
(Post 378065)
And these are measured on a cold engine.
Yes I have new PC and not sure if it was still there and had to make sure those numbers are accurate. This is a great forum and I thank you all for your replies did not mean to waste anyone's time.
You didn't.......you should see some of my off topic posts :)
