1995 2.2 Liter 4 cylinder VTEC valve lash adjustment
Old Dec 9, 2017 | 03:34 PM
RA1525's Avatar
Default 1995 2.2 Liter 4 cylinder VTEC valve lash adjustment
Hi, have a 95 Accord 2.2 4cylinder VTEC and new timing belt job will be done soon while the valve cover is off would like to check if "valve lash are within spec" but can not find the specs for intake or exhaust. Do any of you know a reliable source to find the specs? Thank you.
Old Dec 9, 2017 | 06:08 PM
Should be a sticker under your hood with the valve clearance. Here are the SAE and metric values from the shop manual.
Intake: 0.010 +/- 0.0008 inches (0.009 to 0.011 inches)
0.26 +/- 0.02 mm
Exhaust: 0.012 +/- 0.0008 inches (0.011 to 0.13 inches)
0.30 +/- 0.02 mm
Old Dec 9, 2017 | 11:22 PM
RA1525's Avatar
Default Thank you
0.26 +/- 0.02 mm
0.30 +/- 0.02 mm
Thanks PAhonda!
Old Dec 11, 2017 | 06:09 AM
And these are measured on a cold engine.
Old Dec 15, 2017 | 07:10 PM
Old Dec 23, 2017 | 01:40 PM
RA1525's Avatar
Yes I have new PC and not sure if it was still there and had to make sure those numbers are accurate. This is a great forum and I thank you all for your replies did not mean to waste anyone's time.
Old Dec 25, 2017 | 10:12 AM
You didn't.......you should see some of my off topic posts
ibettysman35773
Apr 28, 2013 07:48 PM
ibettysman35773
Apr 28, 2013 06:40 PM
DevlinDevil
Mar 23, 2013 03:28 PM
RA1525
Oct 1, 2011 10:53 PM
huzzsaba
Dec 19, 2006 09:37 PM
