1995 honda accord speedometer not working
Old Feb 3, 2016 | 11:10 AM
DemiGodOdin's Avatar
Default 1995 honda accord speedometer not working
Hello I have a 1995 honda accord ex coupe 5 speed with a vtec motor in it, not a swap motor. I bought it and saw that the speedometer didn't work so I replaced the speed sensor and cleaned the connector that plugs into the speed sensor and put everything back. I started the car and saw that the needle was jumping all over the place and I was only going in reverse and drive in my driveway, the car then shut off and a wire behind the throttle body burned and the ecu fuse in the engine blew. I replaced the fuse and reconnected the burnt wire and the car started up. Now I unplugged the connector to the speed sensor because I'm scared it will happen again, does anyone know why this happened and what I could do to get the speedometer and odometer to work again. Thank you for any help.
Old Feb 5, 2016 | 06:43 PM
I'd start by inspecting the wire harness to the VSS (assume that is what you replaced) and see if there are any spots where the wires are exposed and possibly grounding out.
Renee Townsend
Feb 17, 2015 10:40 AM
dulamt
Jan 15, 2013 04:06 AM
billyspvy
Jul 31, 2012 11:56 PM
jackmd
Sep 15, 2011 06:11 PM
accordEX99
Nov 3, 2008 02:22 AM
