Speedometer/odometer/cruise not working 96 accord
Old Sep 11, 2011 | 08:06 AM
jackmd's Avatar
Unhappy Speedometer/odometer/cruise not working 96 accord
I recently swaped out my 2.2l non vtec engine in my 96 accord. When I started it up the D4 light was on solid. The car would only start off in high gear. Found that one of the solenoids on the trans was not properly plugged in. Now the trans works fine and D4 light is off. But, my speedometer and odometer haven't worked since. I have 500 ohms on both speed sensors front and back of trans. Also measure 0.269 volts at both connectors. I visually inspected both sensors for damage - none. Everything worked fine until the engine swap. Also, I only swapped the engine. I still have the same trans, sensors, etc.
Any help with troubleshooting would be greatly appreciated.
Old Sep 11, 2011 | 08:26 AM
The VSS is where you need to be, just want to be sure we are talking about the same sensor....down almost right under the tb.
Attached Thumbnails Speedometer/odometer/cruise not working 96 accord-5th-gen-trans-sensor.jpg
Old Sep 12, 2011 | 03:49 PM
jackmd's Avatar
I don't know what you mean by tb.
Thanks for the reply
Old Sep 12, 2011 | 04:53 PM
TB = throttle body.
Stop by a parts store and have them scan for codes. You OBD2 connector is behind the ash tray. Post any codes on here.
Old Sep 15, 2011 | 02:56 AM
jackmd's Avatar
Thanks for the help. Found the correct sensor under tb. It was'nt plugged in.
Thanks again
Old Sep 15, 2011 | 06:11 PM
You got it solved, that is what is important. Thanks for the follow up. Its nice to know how the story ends.
Renee Townsend
Feb 17, 2015 10:40 AM
csh217
Apr 30, 2013 09:03 PM
guy91
Jan 29, 2012 10:01 PM
trilliput
Aug 18, 2011 11:03 PM
