1997 accord auto trans problem
Old Apr 27, 2010 | 09:30 AM
57explorer's Avatar
Default 1997 accord auto trans problem
i have an 97 accord w/an auto trans. when i go in reverse it makes a loud clunking sound almost like a pop can being crushed and seems to stall for a moment, then it goes again. there are no ecu codes that come up. any help would be very helpful
Old Apr 27, 2010 | 09:59 AM
Can you pinpoint the location of the sound? Open the hood, have someone hold the brake & shift. Look for excessive motion (bad engine mounts) or at least get a better idea of the location of the sound.
Old Apr 27, 2010 | 10:25 AM
57explorer's Avatar
the sound comes from the area where the axle on the drivers side goes into the trans
Old Apr 27, 2010 | 12:09 PM
And I forgot to ask... V-6 or 4-cyl? Those may as well be completely different cars 'cause they have so little in common.
I'm not much an auto-trans expert so I hope someone else chimes in. But crunchy noises like that - if it originates within the transmission itself - doesn't sound good.
Fluid level OK? Fluid condition (hope the fluid isn't 12-years old)?
Maybe the sound is the inboard CV joint of the axle??
Old Apr 27, 2010 | 12:15 PM
57explorer's Avatar
it's a 4 cyl has around 160k miles on it, fluid and cv joints were changed about a year ago, it was making that noise before that so i thought it might have been one of them, turns out it wasn't
habbababba
Aug 22, 2011 11:32 PM
den524
May 25, 2011 10:19 PM
ECV4LIFE
Apr 15, 2010 08:09 PM
bmarshall
Jan 3, 2007 08:54 PM
mbo1985
Mar 25, 2006 04:07 PM
