1997 accord se
Old Feb 1, 2013 | 09:35 PM
fwartan@sandc.com's Avatar
Default 1997 accord se
Hello, I have a1997 accord se,having problems. My car turns over but wont stay on. I replaced the cap, rotor, plugs, spark plug wires, fuel pump relay timing belt 2 weeks ago. I check all fuses and there all good... it dosent do it all the time. when its does start rpms seem a bit low until I step on the gas pedal. please help need advice
Old Feb 2, 2013 | 02:07 AM
Lightbulb Hello New Member..Please Follow The Link Below.
Click the link and do some reading please
https://www.hondaaccordforum.com/for...ed-help-24592/
Old Feb 2, 2013 | 10:55 AM
go-part's Avatar
Former Sponsor
Lesson learned, troubleshoot and test first then buy parts.
You could have saved alot of money because the problem you are having could probably be solved by checking and cleaning your IACV and throttle body.
Old Feb 3, 2013 | 06:44 PM
Check my writeup in DIY about setting the base idle. Some things that can affect that are vacuum leaks, air in the cooling system, etc. as listed in that post.
With age & mileage, a lot of the things you replaced might have been overdue normal maintenance, so maybe not wasted money/effort.
Old Feb 4, 2013 | 09:00 PM
Default Accord turn over but wont stay on
Hello, I have a 1997 accord se ,automatic, 4 cyclinder. Ok my problem is my accord turnover but wont stay on.....this dosent happen all the time. And sometimes its starts but hesitates until I put my foot on the gas. I just replaced the fuel filter 2 days ago and thought this solved the issue... still havin the problem..and in my previous post I replaced the spark plug wires, spark plugs, cap , rotor ,timing belt, water pump, radiatior...checked and theres no air in the cooling system. Checked all fuses and there fine. Also had a friend hook up his odb or obd to the computer( behind the ash tray) and theres no codes. My next step is to clean the iavc and throttle body.this was quoted on my last post so I will take any advice at this time. If anybody reads this and they had the same issue please chime inn and leave advice. And anyboby please advise on what I should do next
Thanks in advance
Fred
jpfeifer
May 8, 2006 05:52 PM
realmc1969
Jan 25, 2006 09:54 PM
Marko
Dec 4, 2005 02:14 PM
jcharvolin
Sep 26, 2005 05:53 PM
Marko
Aug 9, 2005 09:40 AM
