1997 Accord slipping on 4th gear, sometimes 3rd
Old Feb 18, 2021 | 12:41 AM
can-of-soda's Avatar
Question 1997 Accord slipping on 4th gear, sometimes 3rd
I bought ATF DW-1 fluid for my '97 Accord automatic (F22B2). Not sure when the last time the fluid was changed (likely been over a couple years..), there was a sizable amount of stuff on the magnet and the fluid was pretty dark. After doing one change of fluid (~3qt.) the car seemed to drive very well. The next day I drive it, and it's slipping again. Not as bad as before but it's noticeable.
I've noticed that in D3 the transmission shifts just fine, but when I'm in D4 and reaching about ~45mph is when it slips. 3rd will also slip sometimes when it's in D4, this is just really odd to me. Sometimes I'll just keep the car in 3rd when I reach 45mph then move it to D4 just so it doesn't slip. Should I keep changing the fluid until it's clean (will that ruin it?) or is there another underlying cause that could help this issue? Will cleaning the shift solenoids help much? No CEL comes up at all either.
Old Feb 18, 2021 | 12:58 AM
One drain removes about 30% of the fluid, so a second drain an refill may help. If the issue is the clutch friction discs, then a fluid change isn't the cause of a slipping transmission.
Cleaning the shift and lockup solenoids and screens may also be a good idea.
Old Feb 18, 2021 | 04:55 PM
Sweet, thank you
Old Feb 24, 2025 | 06:31 AM
roliv's Avatar
Default similar problem
Originally Posted by can-of-soda
Sweet, thank you
Hi! I have a somewhat similar problem. Slip or flare from 1st to 2nd when D4 selected but not when D3 is selected.
Were you able to pinpoint your problem?
Thanks
cukaracha
Apr 6, 2015 04:48 PM
TornCalfGuy
Jan 4, 2014 07:43 AM
camman
Aug 26, 2013 10:04 PM
h8crew
Jul 21, 2012 02:21 AM
coolgmslife
Feb 28, 2007 10:54 PM
