1997 honda accord idle issue
Old May 9, 2018 | 11:48 AM
sjkemp27's Avatar
Default 1997 honda accord idle issue
hello everyone, when I am driving my vehicle my idle will rev up and down from time to time but only when I have the air conditioning on. If my ac is off it idles fine. I'm wondering if its a fuel issue but I don't think so. it is well over due for a timing replacement as well.. I have no clue what it could be. any help will be appreciated. thank you
Old May 9, 2018 | 03:04 PM
With this topic you'll get more help in General Tech, so I'll move it.
The first thing to do is adjust your "base" idle. Honda idle-control systems don't like to be adjusted while the IACV is plugged in & working. Check this thread & go through that procedure.
https://www.hondaaccordforum.com/for...e-speed-38734/
If that doesn't help, then it's possible something is off with your AC causing it to have excessive drag on the engine. It sounds like there's no problem with the idle when the A/C is switched off?
Old May 9, 2018 | 05:19 PM
The Toecutter's Avatar
Keep in mind that the 97 still used the "FIT" valve.
Old May 9, 2018 | 05:25 PM
Pretty sure the base idle adjustment procedure is the same.
The FITV is another component that might be flaky, but that would be flaky whether the AC is turned on or off.
Old May 10, 2018 | 08:03 AM
sjkemp27's Avatar
Default Idle issue
There is no problem with the idle when ac is off. I'm going through the procedures right now to adjust it and reset ecu
Old May 10, 2018 | 09:36 AM
sjkemp27's Avatar
Default No more idle issue
Everything is working great. Thanks for your help. Ac stays cold while it's in park. Never did that before until i made adjustment
oldhonda7
Feb 7, 2017 06:22 PM
U&H
Jun 13, 2013 07:06 PM
miro066
May 28, 2013 03:39 PM
robdigga
Aug 29, 2012 10:56 PM
warrenDar
Nov 7, 2010 10:41 AM
