1997 honda accord idle issue
hello everyone, when I am driving my vehicle my idle will rev up and down from time to time but only when I have the air conditioning on. If my ac is off it idles fine. I'm wondering if its a fuel issue but I don't think so. it is well over due for a timing replacement as well.. I have no clue what it could be. any help will be appreciated. thank you
With this topic you'll get more help in General Tech, so I'll move it.
The first thing to do is adjust your "base" idle. Honda idle-control systems don't like to be adjusted while the IACV is plugged in & working. Check this thread & go through that procedure.
https://www.hondaaccordforum.com/for...e-speed-38734/
If that doesn't help, then it's possible something is off with your AC causing it to have excessive drag on the engine. It sounds like there's no problem with the idle when the A/C is switched off?
oldhonda7
Feb 7, 2017 06:22 PM
robdigga
Aug 29, 2012 10:56 PM
