1997 Honda Accord Special Edition A/C and radiator issue
I have a 1997 Honda Accord Special Edition I bought recently. When i turn on the AC the car runs fine but then when i turn off the car and the AC, water spills out of the the expansion tank for the radiator. The car overheated once due to this issue. I would help or a possible diagnosis for his issue. By the way when i turn on the AC the fan on for the radiator comes on but the fan for the engine doesn't. Help Please!! Thank you
I'd start by figuring out that fan that is not working.
When the engine is cold, start up the car and turn on the a/c. Try hitting the motor of the fan with the handle of a screwdriver to see if that fan will turn on.
If you have a volt meter, you can unplug that fan's electrical connector and test for 12V going to that plug when the engine is running and the a/c turned on.
i checked all of that and come to find out the fan motor was bad so replaced it and now both fans work when the a/c comes but water still spills out of the reserve tank when the a/c is on... could this be the water pump?
