1997 Honda Accord Special Edition A/C and radiator issue
Old Aug 26, 2012 | 11:26 AM
I doubt that it is the water pump, and that would be the last component I would consider checking.
Is the engine overheating with the new fan installed?
Old Aug 26, 2012 | 11:54 AM
firefighter44's Avatar
Almost A Senior Member
PAhonda could it be the thermo switch 2 or thermo sensor 2(whatever its called) gone bad.
the one that senses the upper temp causing the fan fan to cut off to soon?
Old Aug 26, 2012 | 12:26 PM
Have the rad cap tested or replace it.
Old Aug 28, 2012 | 05:01 PM
robdigga's Avatar
the car doesnt over heat it doesnt get to the point yet. but after i turn off the car water comes out the reserve tank. but it only happens when the a/c is on
Old Aug 28, 2012 | 06:40 PM
Engine and coolant are slightly hotter when AC is used and overflows due to a weak radiator cap relief spring or possibly a thermostat that is allowing temperature to get a bit too high. Hopefully radiator cap will fix.
Old Aug 29, 2012 | 07:51 PM
robdigga's Avatar
the thermostat isn't in the car anymore. thats the 1st thing i checked. so now i'm gonna try to change the radiator cap
Old Aug 29, 2012 | 08:59 PM
  #17
Hopefully radiator cap will fix, otherwise head gasket leak is likely.
Old Aug 29, 2012 | 10:56 PM
  #18
One other thing you can try, when you start having the coolant problem, touch the upper and lower radiator hose. Do this quickly, because those hoses are HOT. Is there a noticeable difference in temperature?
sunnyday12
May 7, 2015 06:10 AM
Hammertime
Mar 28, 2015 02:01 AM
jward619
Sep 2, 2014 05:41 PM
edpup316
May 20, 2011 10:03 PM
jpfeifer
May 8, 2006 05:52 PM
