1997 Honda Accord Special Edition A/C and radiator issue
Old Aug 21, 2012 | 06:39 PM
robdigga's Avatar
Exclamation 1997 Honda Accord Special Edition A/C and radiator issue
I have a 1997 Honda Accord Special Edition I bought recently. When i turn on the AC the car runs fine but then when i turn off the car and the AC, water spills out of the the expansion tank for the radiator. The car overheated once due to this issue. I would help or a possible diagnosis for his issue. By the way when i turn on the AC the fan on for the radiator comes on but the fan for the engine doesn't. Help Please!! Thank you
Old Aug 21, 2012 | 09:12 PM
is this a 4 or 6 cylinder? Which fan does not turn on when you turn on the a/c (driver or passenger side)?
Old Aug 22, 2012 | 08:54 PM
robdigga's Avatar
4 cylinder, the driver side fan doesnt come on
Old Aug 22, 2012 | 10:42 PM
I'd start by figuring out that fan that is not working.
When the engine is cold, start up the car and turn on the a/c. Try hitting the motor of the fan with the handle of a screwdriver to see if that fan will turn on.
If you have a volt meter, you can unplug that fan's electrical connector and test for 12V going to that plug when the engine is running and the a/c turned on.
Old Aug 23, 2012 | 05:09 PM
robdigga's Avatar
so when i turn on the A/C both fans need to turn on?
Old Aug 23, 2012 | 05:13 PM
robdigga's Avatar
just a reminder the passenger side fan comes on when i turn on the a/c
Old Aug 23, 2012 | 06:23 PM
Both should come on with the AC. And both should come on with overheating while the engine is running.
Old Aug 23, 2012 | 08:05 PM
robdigga's Avatar
thanks Jim. thats what i thought but i wasnt fully sure. i tried what pahonda said and the fan still didn"t work i"m gonna buy a new fan see what happens. i'll give u an update thanks
Old Aug 24, 2012 | 06:59 PM
You mean you hitting the fan or hot-wiring it? If hitting it doesn't work, did you go on to hot-wire the fan motor? You might have a wiring problem, so make sure the fan motor is actually bad..
Old Aug 26, 2012 | 11:15 AM
robdigga's Avatar
i checked all of that and come to find out the fan motor was bad so replaced it and now both fans work when the a/c comes but water still spills out of the reserve tank when the a/c is on... could this be the water pump?
