1998 ACCORD A/C ?
Old Nov 7, 2007 | 10:25 AM
dboy's Avatar
Default 1998 ACCORD A/C ?
My Air conditioner in my 1998 HOnda accord is not blowing through the middle vents.It is coming out where the defrost is.I have it on the correct button to blow out of the front vents...but it's like it's still blowing out by the windshield.. Anyone encounter this problem?.
Old Nov 7, 2007 | 10:32 AM
falkore24's Avatar
Default RE: 1998 ACCORD A/C ?
Sounds like a bad actuator ..... but this is a question for deserthonda!!!! oh yeah .... DH, this one is air!!! LOL
Old Nov 7, 2007 | 10:33 AM
dboy's Avatar
How much does actuator cost?
Old Nov 8, 2007 | 12:56 AM
2POINTautO's Avatar
Disconnect Mode Control Motor. Jumper a fused power wire to mode control motor terminal #2. Jumper a ground to mode control motor terminal #1.
Motor should cycle and stop at vent mode. Disconnect jumpers after motor has stopped, IMMEDIATELY. Reverse jumper connections, swap #1 to #2 and #2 to #1 (reverse power and ground). Motor should cycle and stop at defrost mode. Disconnect jumpers after motor has stopped, IMMEDIATELY.
If mode control motor does not run when jumping terminal #1, jump terminal #1 again after jumping all others. Mode control motor is ok if it runs after jumping terminal #1 again.
Use a multimeter to check for continuity between terminal #7 and teminals #3, 4, 5, and 6 while manually cycling motor between vent and defrost. Continuity should be indicated on each terminal momentarily while motor is cycling.
With the locking tab facing up, terminal #1 is on the far left and termainal #7 is on the far right. See colors below for orientation.
The mode control motor is completely controlled by the AC Control Head
AC Control Head 20 pin connector = Mode Control Motor 7 pin
5 = 1 BLU/BLK
6 = 2 BLU/WHT
11 = 7 YEL/GRN
17 = 3 BLU/GRN
18 = 4 LT GRN/BLK
19 = 5 GRN/YEL
20 = 6 GRN/BLK
This is for Auto AC, thought I would get ahead in case yours was auto. The mode control motor should be down on the left side of the heater box, center console, near your feet. 7 pin connector.
If this is not correct, then let me know.
Old Nov 8, 2007 | 07:48 AM
falkore24's Avatar
it looks like 2point has your diagnostics covered ....... I'd never have come up with that btw. For parts pricing, the site of choice here is Majestic Honda...... you should be able to look up parts there.
Old Nov 9, 2007 | 01:27 AM
2POINTautO's Avatar
I am working on a huge AC project dealing with diagnosing Honda AC systems. If you have a digital camera and can post pic or send me pics, it would be a huge benifit to me and all folks I help in the future with a similar problem.
http://forum.pgmfi.org/viewtopic.php?t=2007
Bottom pic style is mainly what I am looking for and anything else that you may play with fitting the style of the other pics too please.
Old Nov 12, 2011 | 02:05 PM
yunus.jay's Avatar
Default a/c vent mode not working on honda accord 98 4 cyl. 5 speed manual
I have trouble on how to fix a/c vent mode on my honda accord 98 lx 4 cyl. 5 speed manual trans. the air only comes out in front of the dash board, all the bottons work, and the light indications follow where you select the vent, but it doesnt blow on the floor or in the front defrose, is there anyone experience this problem? please...please...please... help me how to troubleshoot...
any respond will be very much appreciated...
thank you in advance...
honda accord 1998, 4 cyl. 5 spd. manual.
Old Nov 12, 2011 | 03:05 PM
Don't have much on the 6th gens. There should be a mode control motor, check the linkage is not binding.
Old Nov 20, 2011 | 10:07 PM
yunus.jay's Avatar
ill check that out...any idea how to check the motor of the vent... thank you very much guys....
Rilex
Aug 14, 2015 12:04 AM
IntegraGSR
Oct 5, 2010 08:43 PM
Zambo
Jan 18, 2006 11:19 AM
AHPE1234
Sep 13, 2005 01:45 AM
mercski
Nov 26, 2004 07:39 PM
