1998 Honda Accord EX - Replacing The fuel pressure regulator
Old Feb 8, 2011 | 04:46 PM
The small one without the clamp is the vacuum hose. It *should* just pull off, but they're usually stuck on with heat & age. Begin twisting and it should come off once you get it moving. It's on a smooth steel tube, no barbs or threads, but pushing & twisting seems to work better than pulling.
The big one probably has a spring clamp, where you use a pliers to squeeze the tabs together which loosens the clamp. Kinda like the spring-type radiator hose clamps.
Old Feb 9, 2011 | 12:48 AM
techjohnny's Avatar
What a mess, but things seem OK now. I removed the two bolts and attempted the remove the hoses, but my tools weren't sufficient, so I decided to bolt the FPR back on, and this is where things get messy.
After bolting the FPR back on and starting the car, fuel started gushing out of the FPR, I didn't realize that the o-ring fell off. It was 515PM PST and the shop I normally go to was still closed, but the Open light was on, so I walked in. The manager got a mechanic to remove the hoses and put the new FPR for me, and now the FPR is on and working perfectly.
So far the "Check Engine" light has stayed off, which was displaying the codes P0170 and P0171.
I'll keep this thread up-to-date in-case something changes.
Much regards,
--tj
Old Feb 9, 2011 | 01:21 AM
Good post and Great Help from Jim as always..Thank You James
Old Feb 10, 2011 | 05:24 PM
techjohnny's Avatar
The car no longer requires me to "feather" the peddle to get it to accelerate properly, but both codes P170 and P171 are back. Might want to replace the O2 sensors?
--tj
Old Feb 11, 2011 | 07:28 AM
P0171 = system too lean
Only the front O2 sensor is involved in that.
Got any ignition misfiring? Misfiring will result in excess unburned fuel and excess un-used oxygen. The excess oxygen is the only thing the O2 sensor can measure.
Old Feb 11, 2011 | 11:10 AM
techjohnny's Avatar
This is before and after a new engine install, and I don't suspect any misfiring.
--tj
Old Feb 19, 2011 | 02:01 PM
  #17
techjohnny's Avatar
Well after replacing the FPR, car was still driving funny and codes P0170 and P0171 came back after driving a couple hundred miles. Well, I disconnected the O2 sensor under hood, and now car seems to be driving fine.
So, guess my O2 sensor needs to be replaced? How does disconnecting the O2 sensor affect my car?
Thanks
Old Feb 19, 2011 | 07:26 PM
  #18
When it's disconnected, control goes into "open-loop" and generally gets richer. So if that improves things, it may be too lean for some strange reason.
Vacuum leak?
TPS needs adjusting?
MAP sensor OK?
Old Feb 20, 2011 | 09:22 PM
  #19
techjohnny's Avatar
This is happening before and after engine replacement. Can I check for vacuum leak or will a shop need to check for leak?
Thanks
djalmab
Jun 13, 2018 02:38 AM
djames
Jul 21, 2013 10:00 PM
RobinsonRicer
Jul 30, 2012 03:21 PM
jamrock
Nov 14, 2008 02:17 PM
martinh
Aug 31, 2007 12:35 PM
