1998 Honda Accord rattles
Old May 21, 2012 | 01:05 PM
rockhoundrob's Avatar
Default 1998 Honda Accord rattles
I have a 1998 Honda Accord 160,000 miles. There is a rattle that I am pretty sure its in the suspension area. I took it in to have it aligned and they said it was OK. More of a loose rattle in the front suspension and not like a loose muffler. More like a loose rubber thump against metal and not metal to metal. I know it is not engine mounts.
What else can I look at? I kind of think it a bad brushing. What about a loose swaybar? Can that cause it? It usually happens when I am turning or going over a little bump. It almost sounds like the shock absorners are loose, but thats is not it.
thanks!
Old May 21, 2012 | 07:30 PM
The anti-roll bar bushings are a common reason for that.
Also check the radius-rods. They attach to the lower control arms, and go forward where they are bolted into the frame structure. That forward end is easy to miss (if it's loose).
rwyatt80
Jun 14, 2012 07:51 PM
dougnchgo
Apr 12, 2011 07:10 PM
dgp1961
Mar 8, 2010 07:39 PM
dragonle87
Aug 31, 2009 09:41 PM
rikee
Jul 8, 2008 06:38 AM
