1999 4 cyl LX Calif ULEV p1164 DTC
Old Nov 3, 2014 | 01:06 PM
grannie613's Avatar
Default 1999 4 cyl LX Calif ULEV p1164 DTC
CEL came on yesterday and I am checking it today: the car drives just fine w/o any roughness. P1164 indicates a problem with primary(under the hood) air/fuel ratio sensor. The resistance across the black leads of the sensor pigtail is 0.1-0 .2 ohms. I then checked the #6 fuse in the pass. side kick panel...fuse is good. With the pigtail still disconnected and turning the ignition to ON I observed voltages of 2.75 v and 11.81v at the terminals which correspond to the black leads. I decided that it was only a sensor failure and that I needed a replacement. After doing several searches I am totally confused at to which part I need. I prefer a middle-priced Denso one if I could just figure out the right part #.
Old Nov 3, 2014 | 02:16 PM
Your Accord 4 cylinder ULEV uses Honda part number 36531-PAA-307, which cross-references Denso part number 234-9025 for the air/fuel ratio sensor.
rjpjnk
Jun 16, 2016 11:40 AM
richcabras
Aug 14, 2014 10:34 AM
JOE.G
Apr 9, 2013 08:51 AM
jhillblessed
May 10, 2010 09:55 AM
voteforpedro
Oct 28, 2009 11:53 AM
