1999 AC Problem
Old Jun 19, 2011 | 10:21 PM
SierraGT's Avatar
Default 1999 AC Problem
Hey, I just inherited a 99 Accord and I'm having a problem with the AC. The air blows, but the part of the dash where you can select AC, defrost, etc doesn't work. I have no idea what that part is called. I'd like to find out what it is and order the part repair it myself if possible. I've attached a picture to show what I'm talking about. Any help would be great, thanks.
Old Jun 20, 2011 | 12:03 AM
It will be called the climate control panel, HVAC control panel, or maybe mode control panel.
If you plan on doing DIY work, I highly suggest buying a shop manual. I bought one for my TSX from automanualsource on ebay for $22 and downloaded it immediately. It is well worth the investment and will pay for itself if you do one DIY project using it.
I would do some electrical troubleshooting first. It is possible that the wiring or a fuse is the problem. It is also possible that the panel is working properly, but the mode control motor under the dash is bad. You will need a volt meter to do these tests.
Old Jun 20, 2011 | 07:26 PM
Hey, maybe one for the "common" threads.....HVAC codes on a 6th gen?
helpmehonda
Jul 3, 2008 12:28 AM
ZMan3000
May 11, 2008 07:56 PM
1999accord_SC
Jun 19, 2007 03:01 PM
Derrick Stevens
Jun 13, 2007 02:52 PM
banjuju
Apr 12, 2007 04:35 PM
