1999 Accord stops intermittenly
Old Oct 15, 2012 | 10:26 AM
JEQuien's Avatar
Lightbulb 1999 Accord stops intermittenly
My 1999 Accord 4 cyl quits running intermittenly. I can put it in nutral, start it right away and be on my way. May not happen again for several days. No fault codes. Driving me nuts! What could it be?
Old Oct 15, 2012 | 11:47 AM
When engine fails do all the panel system lights(Check Engine, Oil, Alt) come on or stay off? If off, the ignition switch assy failure is likely.
Since fault is intermittent, it may be diffcult to observe above. Sometimes switch assy failure can be "induced" by wiggling or slightly twisting ignition key position.
Good news is a new keyswitch assy is simple and relatively inexpensive part (< $50).
It could be an intermittent main fuel relay (MFR), however this will be difficult to determine since engine starts immediately after failure. Symptoms for failed MFR are no relay clicks from under the dash and no fuel pump buzz from fuel tank when keyswitch is turned to On. When these conditions are present, engine will not start (no fuel pressure).
Old Oct 15, 2012 | 12:35 PM
JEQuien's Avatar
Thanks for the help! The panel lights DO stay on. I thought it might be a relay problem, so I think I will head in that direction.
Old Oct 15, 2012 | 04:23 PM
steveare's Avatar
Default engine failure en route
I am also looking for cause(s) of engine shutting down (especially when i'm in the fast lane going down the highway -- way disconcerting), and had wondered if the fact I have yet to have the serpentine belt replaced on my 1997 Accord LX 4-cylinder had anything to do with it but from what I gather in the quote below it doesn't. My question: are you saying if the the panel system lights stay on it's a faulty MFR?
GhengisFong
Jun 29, 2014 01:46 PM
gjm
Jun 17, 2011 10:24 PM
swhitney11
Oct 14, 2008 08:45 PM
sinister1
Mar 18, 2008 05:45 AM
krafte12
Sep 9, 2005 09:36 PM
