1999 Accord V6 fluid pressure test port?
Old May 18, 2016 | 08:06 PM
I didn't mean that gasoline was leaking from the fuel rail. If you lose pressure in the system over time, the gasoline is flowing back to the gas tank. There is a check valve that should prevent fuel from flowing back to the gas tank. That check valve could have failed. Unfortunately, it is part of the fuel pump.
Old May 18, 2016 | 08:35 PM
Newhond's Avatar
Is there any way to test the check valve?
Old May 18, 2016 | 09:14 PM
You have to measure the pressure in the fuel system and verify the pressure drops when the car sits overnight.
Old May 19, 2016 | 08:15 AM
Newhond's Avatar
The car start fine this morning with the technique you showed me. So, the main issue is the check valve not holding fuel pressure. However, I still not find the port where to connect the fuel pressure gauge to check it.
Old May 19, 2016 | 08:53 AM
shipo's Avatar
At this point checking the fuel pressure is pretty much moot.
Old May 24, 2016 | 02:01 PM
It may be that turning the key & pausing for even 1 or 1/2 second at the RUN position will make it start right up. Try & see.
The fuel pressure can leak back to the tank by 2 different paths. The check-valve in the fuel pump can leak back into the tank.
Or the FPR (on the return line) can leak slowly. So the fuel bleeds through the FPR & the return line back to the tank.
Check the vacuum hose on the FPR, shortly after turning it off. You shouldn't have any gasoline in there. Besides running rich, that is another place for the pressure to bleed off, but if that's happening you would have other issues like flooding.
Old May 26, 2016 | 07:01 AM
  #17
Newhond's Avatar
Thank you all. With all your help, now I know what cause the issue.
I'll replace the FPR first because it's cheaper and the next thing is fuel pump.
However, if someone know where to check the fuel pressure (1999 Honda accord V6) then share with me.
Old Jan 15, 2022 | 04:24 PM
  #18
pogoto's Avatar
NewHond,
Did you end up figuring out what was the problem? I am having the same symptoms for my 99 v6 Accord too.
Old Jul 29, 2025 | 09:17 PM
  #19
Wombat's Avatar
Default Knock, knock
Guys, what a worthless thread! No one ever actually answered the question. How do we perform a fuel pressure test on 1999 accord v6? There doesn't seem to be a great place.
Old Jul 29, 2025 | 10:56 PM
  #20
The shop manual says to remove the fuel pulsation dampener, then use a special gauge that will thread into where the pulsation dampener normally resides. You are essentially teeing in to the fuel supply hose with a gauge. I don't know if the fuel pressure gauge you can rent from the parts stores would have a the proper sized fitting like the dampener or if you have to get creative with fitting somewhere else to t-into the fuel supply line.
saveabuckchuck
Jul 20, 2020 07:26 AM
richard9
May 31, 2015 02:18 PM
djames
Jul 21, 2013 10:00 PM
chaza
Oct 29, 2012 05:07 PM
draser
Aug 13, 2007 06:07 AM
