1999 Accord vtec EX 90000 mile service
Old Dec 15, 2009 | 10:02 PM
smsmsm
Default 1999 Accord vtec EX 90000 mile service
Hi,
I am getting ready for my 93k mileage 99 vtec EX accord's 90k mile service and need a list of what needs done, and appropriate cost. I had a regular 75k service at 77k with no hiccups.
The 60k was done at 69k and included new front brakes, spark plugs distributor cap n rotor; all belts hoses were ok
What quote should I expect from a Honda dealer (S Minnesota)
Of course timing belt stuff is separate, and that quote is $581. Definitely not worth it, as it does not have water pump, tensioner, etc. that I understand better be replaced along with timing belt at 90k.
Here is what I got from NAPA auto care for 589 (50% labor, rest parts). I would confirm if original Honda parts are used. Is there stuff missing in the list below, I know replace coolant n brake fluid should also be there, but open to comments. Thanks!
LABOR
adjust drive belts
Inspect
brake hoses n lines
driveshaft/propeller shaft dust boots
engine cooling system hoses and clamps
exhaust system
fluid n lubricant levels
front brake system
fuel lines n connections
parking brake
rear brake system
steering gear/rack n boots
suspension components
tie rod ends
Replace
air cleaner element
automatic transaxle fluid
cabin air filter
engine oil 4.5qt
engine oil filter
manual transaxle fluid
spark plugs (In-Line4)
rotate tires
PARTS
Air filter BA5248 $22.88
Cabin air filter 89782 $21.70
V Power spark plug OE Service part 2262 4 x 8.38
Replacement wires Prestolite OE/OES 35-4210 $97.23
Synthetic Transmission fluid VERSA 12 x 6.99 = $83.88
Old Dec 16, 2009 | 07:11 AM
You say timing belt it not worth it? I'd say YES it's worth it. Don't skip the timing belt replacement.
A lot of the stuff you list here is pretty easy for you to do yourself with some instructions from us. Wanna do it that way?
Your auto tranny fluid would be better to use Honda ATF for about the same price. Drain & fill, don't "power-flush". If it drains out pretty clean, you may only have to do that once, for 3 quarts.
Honda factory sparkplug wires seem to last forever. Are they really needed?
Old Dec 16, 2009 | 11:08 PM
deserthonda's Avatar
$ 589 ??? way too much money..and they did not even adjust the valves ........ngk plugs 2262 ,ZFR5F-11 cost around $ 3-3.50 each at Honda dealer........why waste 84 dollars on synthetic tranny fluid??? Honda ATF Z1 is great for this tranny at about $ 6.50 per qt ,why do a flush ??, nothing better than Honda factory plug wires ..
About the timing belt ,, do it ASAP ,,and replace the water pump and all the seals,, cam, crank, balancer shaft and make sure to install a retainer on the balancer shaft seal.also alt and p/s belts
and last,, under the replace items ,, why do you post auto and manual tranny fluid ??
Old Dec 22, 2009 | 10:56 AM
smsmsm
Thanks for writing back
I have not opened the car hood more than twice, is that inexperience enough to not DIY?
Definitely, I wish to replace timing belt, water pump, what all is suggested to be done, once this is being taken care of, and what kind of cost to expect?
(One quote was of 5 hours labor for timing n water pump)
I just elaborated the list, its just auto tranny that i'd need
Old Dec 22, 2009 | 11:05 AM
Replacing air filters & spark plugs is real easy. Changing oil (engine and transmission) is maybe the next easier thing. That needs some pans to drain the old oil, & it's kinda messy, but still pretty easy.
I guess it depends on whether you WANT to begin learning how to do more & more stuff for yourself. You can buy some tools for the cost of shop labor.
With no experience I wouldn't suggest you change your own timing belt.
Old Dec 22, 2009 | 12:17 PM
KevinAccord's Avatar
i thought the timing belt should be replaced every 60k, air filter @ 12k, oil (depends), tranny fluid...(?)...
As for doing the stuff yourself, you should be able to do everything jim said. remember that hondas don't like bosch spark plugs not any other brand of tranny fluid that is not honda's... is you car working well overall?
Old Dec 22, 2009 | 03:02 PM
Timing belt is 100k (maybe 105k) miles, since about 1995 or so.
richybaby
Jan 2, 2011 04:43 PM
garyjatt13
Nov 15, 2008 04:58 PM
accord4sroy
Jun 30, 2007 04:52 PM
dave118811
Nov 8, 2006 05:01 AM
nil
Oct 24, 2006 10:37 PM
