1999 European questions
Old Jan 13, 2009 | 12:22 PM
Tag
Default 1999 European questions
Hi guys, new member, new to Hondas.
Found a really nice 99 Accord 2.0 vtec exec with decent mileage and excellent history (basically new everything in the past couple of years, really well looked after). Bought for a shocking £1200.
Loved it till I was smashed on passenger side. Now there is sub-frame/chassis damage and the car is a write-off.
Didnt claim on insurance as it wouldnt have worked out fiscally.
Now Ive found a cheap 99 1.8 vtec se with a few mechanical issues and hoping I can replace parts from my damaged 2.0. What do you think? Possible?
I live in the UK and have a right hand drive model. Dont know if this changes things...
Thanks in advance guys!
-T
Old Jan 13, 2009 | 12:30 PM
finch13's Avatar
Default RE: 1999 European questions
Im sure a lot of parts will change over, but the engine parts may not be interchangeable.
Old Jan 13, 2009 | 12:33 PM
Tag
Thanks for replying so quickly.
Thats the thing, Im not overly concerned about body / interior stuff like that. I want to know if I can switch out the clutch/ gearbox/ engine parts etc. 1 by 1 or even if I would have to change a whole lot of mechanical stuff all at once.
-T
Old Jan 13, 2009 | 02:47 PM
Sounds like youre talking about taking the whole 2.0 vtecdrivetrain & putting it into thenon-damaged body?
Grab the engine computer too, so it stays with its own engine. Wiring harnesses (on the engine) for the VTEC spool valve, etc. should come along.
Based on owning a 1998 USA Accord, I believe the VTEC engine has added terminals, but none of the terminals/wires from the non-VTEC engine are moved or missing. We can HOPE that the CARs wiring harness is the same & includes all wires needed for either engine.
Non-engine stuff (shock absorbers, brakes, suspension links) should all swap over pretty easily. The non-VTEC car may have rear drum brakes instead of disks??
Still, youre in for a big tedious project... Have fun!
Old Jan 13, 2009 | 03:44 PM
Tag
Thanks for that.
Fortunately the GB versions of accord, I dont think any of them come in non VTEC flavour.
I cant find ANY info online about EU engine or other part numbers to compare with different engine sizes.
Im not very handy with car mechanics but Im assuming you mean I wont be able to chop and change between different engine's (the 2.0vtec to 1.8vtec) drivetrain parts?
So if anything went badly wrong with the 1.8 engine / parts, likelyhood is I would have to replace the entire drivetrain if I wanted to use the parts from my 2.0?
Better start looking for a similar 2.0 then...
Thanks guys.
-T
edit: as far as I know, the 1.8vtec is entirely the same car except for the engine. So all other parts like suspension, brakes, wheels, steering racks etc.etc. are the same.
Old Jan 13, 2009 | 04:07 PM
finch13's Avatar
You can probably mate the transmission to the other engine and vice versa, since they're probably the same family of engines. Can you do us a favor and find the code stamped on the engines? It should be on the front, just below where the cylinder head and valve cover meet near the cooling hose from the cylinder head to the top of the radiator.
Old Jan 13, 2009 | 04:18 PM
Sorry, I misunderstood. When you said the one had mechanical issues, I figured you would find it easier to swap the whole mess.
Sincetheyre both VTEC, theres probably a LOT of parts that can just swap over.
Old Jan 13, 2009 | 05:32 PM
Tag
I might call or email Honda and ask...
I can only get the 2.0 engine number as that is the one I own. Ill do it in the daylight tomorrow. Im only thinking about buying another accord as I have this one sitting in a shed not doing anything...
Prob not the question to ask in here... but Im trying to save money here. I need to get back on the road soon. I can spend about £700 ($1000 ish) on a new vehicle.
Do I...
Buy cheapo Accord (<£500 ideally) and keep mine for parts
OR
Dismantle mine and sell in bits (engine in particular is really tidy) for about £500, if Im lucky, then buy a completely different vehicle?
Its a conundrum!
-T
Old Jan 14, 2009 | 06:42 AM
Keeping the car & parting it out seems like the way to recoup as much money as possible. But its a real pain, a mess that takes up a lot of space, and if that kind of tinkering is not your favorite hobby, its frustrating. Then you have to get someone to dispose of the hulk after youre done.
Third possibility:
Buy a cheapo Accord & swap your real nice engine into it. Pick a car with a good body but sketchy mechanical bits. Better yet, a nice body with a blown engine might be had for really cheap.
Old Jan 14, 2009 | 10:45 AM
finch13's Avatar
Parting out is not the most fun. I spent countless hours tearing my car apart after work...
Pros: Good money
Cons:
- Time
- Hassle
- Space
- Hard to find buyers... until they break something
I still have at least $500 worth of parts in my garage from my last car... only sold about $150 of it.
