1999 Honda Accord 1.8 Auto - Idle problem
Old Jul 6, 2011 | 03:34 AM
GeorgeN10's Avatar
Default 1999 Honda Accord 1.8 Auto - Idle problem
Idle rough when cold, ok when warmed up.
Old Jul 6, 2011 | 10:16 AM
onmyownaccord's Avatar
GeorgN10,
If you're experiencing rough idle when your Accord is cold then I would hasten to guess that either your spark plugs or ignition wires are worn, or that you have a vacuum leak somewhere along the intake manifold/throttle body. Try tightening up all of the clamps around the vacuum pipes to ensure that there is minimal tolerances in the piping fit. Perhaps your intake manifold gasket may even be worn and consequently is causing a rough idle (the intake manifold is ref #11 in this diagram: Part Detail
If everything checks out okay with the ignition wires/plugs as well as the vacuum piping then I would inspect your EGR valve. It could be on its way out and, as a result, it's causing your Accord to idle roughly when the engine is cold.
Old Jul 12, 2011 | 11:13 AM
GeorgeN10's Avatar
Thanks for your useful information.
5.0stang
Mar 27, 2013 06:54 AM
snider
Feb 2, 2012 06:51 AM
snider
Jan 27, 2012 09:51 AM
matias_25
Oct 8, 2011 06:49 AM
GeorgeN10
Aug 24, 2011 07:08 PM
