1999 Honda Accord Fuel Gauge System
Old Mar 21, 2005 | 09:42 AM
rogersah
Default 1999 Honda Accord Fuel Gauge System
Fuel gauge reads full when tank is full but immediately reads about 1/2 only after about 50 miles of driving. I believe either the tank float or sending unit is defective. How does one access the float/sensor? I have heard that it accessible/replaceable via removing rear seat w/o removing the gas tank.
Old Mar 21, 2005 | 12:10 PM
Patrick's Avatar
Default RE: 1999 Honda Accord Fuel Gauge System
i am not certain on that particular application, but the seat should remove pretty easily, and you will be able to see whether or not you can access the top of the tank through that opening.
Old Mar 22, 2005 | 02:56 AM
Hi Rogersah..
You can access the fuel sending unit in the fuel tank through an access hole under the
rear seat with the fuel tank still in the vehicle.
1St make sure that you detach the battery cable from the negative battery terminal, and then loosen the gas cap to relieve the pressure that builds up in the gas tank and here is two cautions.... 1. Dont smoke and 2. if your stereo is equipped with an anti theft system, make sure that you have the correct activation code before disconnecting that battery....
maggiestrd
Jun 28, 2022 07:06 PM
rsttoole
Apr 6, 2013 03:46 PM
letsclique
Jul 16, 2012 06:15 PM
pirulino23
Nov 10, 2010 06:18 PM
woody
Sep 15, 2010 09:20 AM
