1999 honda accord idle problem
Old Jan 27, 2012 | 04:49 PM
snider's Avatar
also note when i unpluged idle air control valve idle went high. and the port on the inside of the car intake body went wide open i put my finger over it and the idle went down to around normal
Old Jan 27, 2012 | 05:57 PM
snider's Avatar
it seams like it idles fine while in park or neutral while parked. When i drive if i put it in to neutral it falls to 1k then goes up to about 1.6-1.7 then very slowly falls down to 1 in about a minute or two
Old Jan 27, 2012 | 09:26 PM
snider's Avatar
I should note the timing belt was just replace by a mechanic, as well as the idle air control valve.
Does any body no the correct denso part # for the IACV on a 99 acord vtech?
I have checked for air in the system and it doesn't seam to have any
Old Jan 30, 2012 | 10:42 AM
Beginning to sound like the new IACV was bad out of the box. But you still want to rule out any other possibilities. That's why it's important to chase down vacuum leaks.
What about the EVAP purge valve (#8 in the picture)? Plug that vacuum hose. The EVAP purge valve should be closed under most circumstances, but if it's stuck open it can be the vacuum leak.
If you have an automatic transmission, another possibility is the vacuum-operated rear engine mount. If it's torn or leaking vacuum, that might be your vacuum leak.
Old Jan 31, 2012 | 11:53 AM
snider's Avatar
Ive checked the evap purge valve it is good. I have checked the mount on the transmission for leakage I applied a vacuum to it and no change in pressure at high vacuum. I'm replacing the fuel regulator as well ordered one figure it can't hurt, I didn't have a fuel pressure gauge to test the pressure.
Old Feb 1, 2012 | 05:56 PM
snider's Avatar
I took the throttle body off and looked at in the light and i could see just a pinch of light coming threw the throttle plate so i backed the throttle set screw back a half a turn and no light put back together problem solved
Old Feb 2, 2012 | 06:51 AM
  #17
Good catch. That throttle stop screw is only supposed to just prevent the throttle plate from wedging stuck closed. I bet someone once used it to adjust the idle.
Airhead
Jul 21, 2014 04:55 PM
mike186abl
Jan 3, 2013 12:01 PM
snider
Jan 27, 2012 09:51 AM
GeorgeN10
Jul 12, 2011 11:13 AM
amcdonal86
May 8, 2011 05:27 PM
