1999 honda accord lx 2.3l
Old May 15, 2015 | 03:39 PM
hondabonda's Avatar
Default 1999 honda accord lx 2.3l
what is the torque spec for the large wheel bearing nut ? 32mm ish
front someone told me was 180lbs is that correct and the rear is ?
Old May 16, 2015 | 08:42 AM
Front, yes 181 ft lbs
Is the rear disc or drum? They are close so not sure if it really matters
Rear Disc = 139 ft lbs
Rear Drum = 134 ft lbs
*According to the manual I have.
Old May 16, 2015 | 10:39 AM
hondabonda's Avatar
thanks its drum . do you know what the torque is for 4 star/bolt style bolts are that attach the backing plate to the spindle?
if you have all the control arm torques also that would be great
Old May 16, 2015 | 11:54 AM
Upper or lower arms? For ~$27 you can buy a pretty nice service manual for the car
Old May 16, 2015 | 12:21 PM
hondabonda's Avatar
the front im fine with its the rear torque specs. I know its not my car didn't wantto buy manual lol thanks if you got it
Old May 17, 2015 | 08:44 AM
Which rear arms are you needing the values for?
Old May 17, 2015 | 09:01 PM
hondabonda's Avatar
for rear drum style the torque specs i need are
backing plate to spindle ---
all 5 control arms both ends ---
lower shock bolt too ---
wheel torque is 80lbfts?
Old May 18, 2015 | 06:06 PM
Are you replacing the rear knuckle?
Attached Thumbnails 1999 honda accord lx 2.3l-6th-gen-drum-knuck-1.jpg   1999 honda accord lx 2.3l-6th-gen-drum-knuck-2.jpg
Old May 19, 2015 | 09:55 AM
hondabonda's Avatar
thank you this should do it for now . the car slide into the curb over the winter and passenger wheels buckled in. so replacing a bunch of stuff
Old May 19, 2015 | 10:07 AM
hondabonda's Avatar
no not replacing the knuckle but most of the control arms
